XZ2 Battery replacement.
GawenTaylor
Nouveau
Hi, can see no related articles so if it is a repeat please point me to the articles TIA.
I have a Sony Xperia XZ2 a little over two years old and in great condition, with the exception of the battery which lasts aroud 24 hours... Do Sony do a battery replacement service and if not can anyone recommend services?
I would be happy to consider a new handset but really like my current one for now,
Thanks in advance.
GDT.
Balises (3)
4 RÉPONSES 4
profile.country.PL.title
najodleglejszy
hi @GawenTaylor, I think your best chance is to contact your local support, as the scope of provided repairs can vary depending on the country or region.
Uliwooly
@GawenTaylor
if you rather do it yourself, there are myriad guides online, make sure to buy the double sided tapes, battery, and if the housing has any physical damage, this is the time to replace it.
https://www.ifixit.com/Guide/Sony+Xperia+XZ2+Battery+Replacement/119369
if you rather get Sony to do it, then do follow @najodleglejszy 's advice, keep in mind that DIY will void the warranty if any
GawenTaylor
Nouveau
Hi,
Thank you for the reply and the advice,
Can you tell me when you say local support are you referring to a third party?
If it can be done by Sony so as not to void a warranty however considering the age of the handset is there any warranty still standing?
Is there any sort of catalogue for support or are you suggesting searching online?
BR
GT
najodleglejszy
by "local support" I meant the branch of Sony support that's covering your area: https://www.sony.net/SonyInfo/SupportAll/
they're going to be the best resource for information about what repairs can Sony provide you.
