xperia xz2 i android auto
profile.country.PL.title
rafalerencompl
xperia xz2 (android 10) cant connect to car with android auto. standard BT connection with car working ok. i changed many usb cabels and no good result. others phones works great with android auto.
2 REPLIES 2
profile.country.PH.title
MarlonUk1
hello
can you make sure the audio cable you are using is CTIA standard.
rafalerencompl
Hello,
i dont understand: audio cable? i used sony oryginal usb cable and many differents cables and no results. car's android auto system still does not see the phone.
