XA massive drain battery by bluetooth... which...is turned off...:D
the XA is drain a battery... its nothing terrible when it is on... but it is off.. but even for "on" its too much drain as for the unused phone.
i've send the phone to the polish service.. but they said that is everything ok with this phone while it was in service.. but as you can se... it isnt...
take a look of the attached screens.
it takes a aprox 3,5h to drain the 25% of battery. so the battery life for this phone is now aprox. 14h when it is in 'stanby' with bluetooth off... but the phone says that bluetooth is on while it is not...
Problem solved via software repair using Xperia Companion.
Thank You. during the night phone grab approx 3-4% of battery.... previously about 20%
Hi
Disable bluettoth options for Yanosik solved the problem with drain battery and bluetooth off/on
