Sony Xperia xa2 mobile stuck at 20%
RISOLTO
donoghue379
Nuovo
My phone is stuck at 20%. the seen how to fix it online but can't get the boot mode going as the manual says. it says hold power button and volume up for 6 seconds but this doesn't work
1 SOLUZIONE ACCETTATA
Soluzioni accettate
profile.country.RO.title
_alexdon_
@donoghue379  You should hold the buttons together for more than 6 seconds, try minimum 10 seconds. The phone will vibrate once (forced restart) and three times (forced shutdown).
alexdon
3 RISPOSTE 3
_alexdon_
alexdon
donoghue379
Nuovo
Cheers, took about 40 seconds before the first vibrate
_alexdon_
Anytime.
alexdon
