Brother I have just reset my phone and on the boot up it asked me for language I selected English United States instead of English United Kingdom and my problem is resolved, not showing mobile data is disabled any more. Try this way may be you get rid of this annoying thing.
Sorry brown it's again appeared. Sony please resolve this issue kindly
I just bought this phone, phone is really good but this notification of mobile data disabled is increasing my blood pressure, Sony it is my request that kindly resolve this issue as soon as possible
Not fixed with 36.0.A.2.146 / R9A
This issue is almost one year old. Phone model is one year old. This means phone is now OLD. A new "version" - revision is out. This means that issue will never be solved. Issues MUST be solved in less than a week. Same way apps are Updated.
This also means That I Will Never Buy a Sony Device AGAIN. I also regret that I bought and Android TV of their make. They fix nothing because they cannot.
When speaking to their representatives it seems like they listen to us as if we are aliens and know nothing about Earth. Specificaly EVERY SOFTWARE malfunction is NORMAL for them and should be the way it is.
Just don't expect a solution to the specific issue. Try to disable or enable Mobile Data through messaging your Provider. There is usualy a message of "START" and "END" or "END DAY".
You will get rid of the headache of this silly annoying message.
Hello Sony, any news?
You are the best, thank for all your updates and quick responses, just keep going
Hi,
I have a problem with my transfer data notification.
When i turn off my data a notification keeps comming up and says "your transfer data is off"
I keep klosing it and dragging the message to the left but it keeps comming back.
Can you tellme what to do so that it doesn't come up?
Hello im new in Sony Xperia,
I always notice the bug in data connection notification, it always notifies that mobile data is disabled, is that normal in sony xperia XA ultra dual?
FYI, i already updated my xpria xa ultra dual to android, but the bug still exists.
Hoping that the next update will fixedthis bug, thanks
follow up on this
Thanks
You can hope, but Sony will never fix it.
Sony Xperia does not listen to its users, unfortunately.
Get used to bugs or sell your phone. With every Sony mobile phone is same story. Check forums.
I don't know in nougat but in Marshmallow you can do a long press on the sign, press info and stop the service then you'll see the sign disappears (you'll see it again when you restart your phone so do it again)
