Делитесь своим опытом!
Такое сообщение выдается при попытке воспроизвести файл со следующим Media info, помогите пжлста разобраться....
General
Unique ID : 244688329138578914142544538776862753419 (0xB815420D23F28E86AB9034C46C0C828B)
Complete name : E:\закачки\Resident Evil Retribution.mkv
Format : Matroska
Format version : Version 2
File size : 13.7 GiB
Duration : 1h 35mn
Overall bit rate : 20.5 Mbps
Encoded date : UTC 2012-12-14 02:40:19
Writing application : mkvmerge v3.4.0 ('Rapunzel') сборка от May 15 2010 09:38:20
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 35mn
Bit rate : 18.2 Mbps
Width : 1 920 pixels
Height : 1 608 pixels
Display aspect ratio : 1.194
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.245
Stream size : 12.1 GiB (89%)
Title : Rip by SeRoGa00
Writing library : x264 core 128 r2216kMod 198a7ea
Encoding settings : cabac=1 / ref=4 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / fade_compensate=0.00 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=9 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0000 / qcomp=0.60 / qpmin=10 / qpmax=69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=40000 / crf_max=0.0 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 35mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 438 MiB (3%)
Language : Russian
Ой! Ой! Как много не нужного! Хотя есть маленькая толика и не интересного.:smileysilly:
1, контейнер мкв, файл похоже 13 с копейками, компрессия 4, поток вроде более 20м многовато но для потока 3д сойдёт, звук ас3 стандарт
Ну увидели мы, кишки контейнера MKV, очень редко в них ковыряюсь, за ненадобностью, проблема явно на 90%; не тут:smileywink:
А в плеерах, кодеках, системе, и т.д.
2, Имена оси, разрядность оси, имена кодеков, плеера, имя зверя, и краткое пошаговое тех задание, как Вы это понимаете так и пишите.:smileysherlock:
Спасибо за ответ!:smileyhappy:
Я не проигрываю файлы ч/з ПК, я подключаю к BDV-N890W жесткий диск... я не понимаю что значит "имя зверя" и "пошагавое тех задание", если не сложно расшифруйте, чтобы я могла предоставить необходимую информацию.
Теперь и я понял с чем имеем дело.
Первый пост считаем Вашим первым горелым блином.
Детально изучаем какими свойствами наделил производитель Ваш девайс.
mkv контейнер и формат матроска, нет слов: да! значит девайс его читать не будет.
То есть ответ мною дан, контейнер мкв и формат матроска это не Ваше, и это говорит только об одном Вы не внимательно читали инструкцию.
Отвечайте откуда он в Вашей коллекции?
А также можете задать ряд других вопросов, на своё усмотрение.
Я поняла из Вашего первого ответа, что медиа инфо - это не нужно и не интересно, но все таки есть еще одна невыясненная деталь.
Следующие файлы mkv (контейнер матроска) мой BDV-N890W благополучно воспринимает:
Полное имя : G:\Downloads\Dredd(3D)2012.halfOU(Ash61)\Dredd(3D)2012.halfOU(Ash61).mkv
Формат : Matroska
Размер файла : 13,2 ГиБ
Продолжительность : 1 ч. 35 м.
Общий поток : 19,7 Мбит/сек
Название фильма : Dredd (3D) 2012 (by Ash61)
Дата кодирования : UTC 2013-01-29 16:16:44
Программа кодирования : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep 2 2012 15:37:04
Библиотека кодирования : libebml v1.2.3 + libmatroska v1.3.0
Видео
Идентификатор : 1
Формат : AVC
Формат/Информация : Advanced Video Codec
Профайл формата : High@L4.1
Параметры CABAC формата : Да
Параметры ReFrames формата : 4 кадры
Режим смешивания : Container profile=Unknown@4.1
Идентификатор кодека : V_MPEG4/ISO/AVC
Битрейт : 17,5 Мбит/сек
Ширина : 1920 пикс.
Высота : 1080 пикс.
Соотношение кадра : 16:9
Частота кадров : 23,976 кадр/сек
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 бит
Тип развёртки : Прогрессивная
Бит/(Пиксели*Кадры) : 0.353
Размер потока : 11,7 ГиБ (89%)
Заголовок : BDrip by Ash61
Библиотека кодирования : x264 core 116 r2074 2641b9eБлагодарю.
Разница очевидна, поэтому я и сделала вывод, что проблема именно в фалах. Я читала инструкцию вроде достоточно внимательно, но так и не поняла в чем проблема... Надеюсь что в итоге она будет не во мне
Спасибо.
Скорее всего, что первый файл закодирован с неподдерживаемым профилем High LEVEL 5. Этот профиль кодирования, в основном является избыточным для кодирования видео Full HD (больше для 4к уже подходит). Обычно для кодирования Full HD используют профили High 4. Соответственно, домашние кинотеатры и плееры также делают с рассчётом, что на них будут воспроизводиться ролики, закодированные с совместимыми соответствующими настройками профиля, похожими на настройки кодирования заводских BD-дисков.
SK-Hardwired, я благодарю Вас за лаконичный исчерпывающий ответ и отсутствие бесполезной критики к моему вопросу (камень в огород kaktys3431)!
Не бейте Кактуса.Он стал таким не сразу.Этот форум и не таких ломал...
