TV BRAVIA - Aggiornamento del firmware alla versione 6.6555
https://www.sony.it/electronics/support/lcd-tvs-android-xf90xx_x90xxf-series/kd-49xf9005/downloads/0...
Vantaggi e miglioramenti dall'aggiornamento precedente
  • Migliora la reattività del TV all'accensione dalla modalità standby
Modelli applicabili
Queste informazioni sono valide per i seguenti modelli di TV:
  • KD-43XG8305
  • KD-49XG8305
  • KD-49XG8377
  • KD-43XG8388
  • KD-49XG8388
  • KD-43XG8396
  • KD-49XG8396
  • KD-43XG8399
  • KD-49XG8399
  • KD-49XG9005
  • KD-55AG8
  • KD-65AG8
  • KD-43XG8096
  • KD-49XG8096
  • KD-55XG8096
  • KD-65XG8096
  • KD-75XG8096
  • KD-43XG8196
  • KD-49XG8196
  • KD-55XG8196
  • KD-65XG8196
  • KD-65AF8
  • KD-55AF8
  • KD-75XF9005
  • KD-65XF9005
  • KD-55XF9005
  • KD-49XF9005
  • KD-65XF8796
  • KD-55XF8796
  • KD-49XF8796
  • KD-43XF8796
  • KD-65XF8599
  • KD-55XF8599
  • KD-49XF8599
  • KD-43XF8599
  • KD-85XF8596
  • KD-75XF8596
  • KD-65XF8596
  • KD-55XF8596
  • KD-49XF8596
  • KD-43XF8596
  • KD-65XF8588
  • KD-55XF8588
  • KD-49XF8588
  • KD-43XF8588
  • KD-65XF8577
  • KD-55XF8577
  • KD-49XF8577
  • KD-43XF8577
  • KD-65XF8505
  • KD-55XF8505
  • KD-49XF8505
  • KD-43XF8505
  • KD-70XF8305
  • KD-60XF8305
  • KD-55XF8096
  • KD-49XF8096
  • KD-43XF8096
  • KD-65XF7596
  • KD-55XF7596
  • KD-49XF7596
  • KD-43XF7596
  • KDL-49WF805
  • KDL-43WF805
  • KDL-49WF804
  • KDL-43WF804
  • KD-77A1
  • KD-65A1
  • KD-55A1
  • KD-75XE9405
  • KD-65XE9305
  • KD-55XE9305
  • KD-75XE9005
  • KD-65XE9005
  • KD-55XE9005
  • KD-49XE9005
  • KD-75XE8596
  • KD-65XE8599
  • KD-65XE8596
  • KD-65XE8588
  • KD-65XE8577
  • KD-65XE8505
  • KD-55XE8599
  • KD-55XE8596
  • KD-55XE8588
  • KD-55XE8577
  • KD-55XE8505
  • KD-55XE8396
  • KD-55XE8096
  • KD-49XE8396
  • KD-49XE8099
  • KD-49XE8096
  • KD-49XE8088
  • KD-49XE8077
  • KD-49XE8005
  • KD-49XE8004
  • KD-43XE8396
  • KD-43XE8099
  • KD-43XE8096
  • KD-43XE8077
  • KD-43XE8005
  • KD-43XE8004
  • KD-100ZD9
  • KD-75ZD9
  • KD-65ZD9
  • KD-49XD8305
  • KD-43XD8305
  • KD-55XD8005
  • KD-49XD8005
  • KD-43XD8005
  • KD-49XD8077
  • KD-43XD8077
  • KD-49XD8088
  • KD-43XD8088
  • KD-49XD8099
  • KD-43XD8099
  • KD-65XD7504
  • KD-65XD7505
  • KD-55XD7004
  • KD-49XD7004
  • KD-55XD7005
  • KD-49XD7005
  • KD-50SD8005
168 RISPOSTE 168
sonysta
Campione
@Bruxk120
Oookkkk....vaaaabeneee😁!
atollok
Buonasera, ho appena aggiornato il tv AG 8, usando la usb, perché al momento in automatico non trovava aggiornamento. Vorrei però fare una domanda a voi piu' esperti, io è il primo tv sony.
Conviene fare questi aggiornamenti ? E , in questo in particolare che migliorie dovrei vedere ?
Ho fatto aggiornamento solo perché con il computer Windows 10 generalmente consigliano di aggiornare sempre.
Ma anche con i TV è cosi ?
Grazie di una risposta, saluti, Luca
Bruxk120
Membro
Come riportato nel sito della Sony, l'unico miglioramento del firmware in questione è il seguente: "Migliora la reattività del TV all'accensione dalla modalità standby".
In ogni caso, a mio modesto parere, se viene rilasciato un aggiornamento, un motivo ci sarà e quindi io lo installo sempre.
Sicuramente altri, molto più esperti di me, ti potranno dare ulteriori delucidazioni.
Saluti. 👋
@atollok anche la versione del Sistema con cui un dispositivo viene rilasciato è in sostanza un aggiornamento, certo probabilmente il migliore e meno problematico al momento ma sempre un aggiornamento uno sviluppo continuo del Sistema.
Questo può comportare che un dispositivo venga venduto con la versione 1.2 di un SO e poi, raggiungendo un ulteriore sviluppo, si abbia la necessità di aggiungere funzionalità o correggere errori con la versione 1.3...
Situazione alla quale si è ormai abituati anche se non è esclusa la possibilità che l'aggiornamento stesso, così come risolutivo per alcuni problemi riscontrati successivamente, quando gli utenti si sono poi trovati ad usarlo con apparecchiature diverse, in paesi diversi eccetera eccetera, non possa introdurre qualche "noia" ma che di certo non è voluta.
Un po' diverso dall'aggiornare Windows forse ma sono anche io dell'idea che devono essere eseguiti, magari rispettando poi il suggerimento di un ripristino delle impostazioni di fabbrica.
dadaumpa87
Buongiorno,
pensate che questi bug risolti nell'aggiornamento dell'immagine allegata verranno risolti anche per modelli della serie xf90?
In pochi giorni ho verificato casualmente che questi bug sono presenti:
- usato cuffie bluetooth AD2P con netflix non mi indica la disponibilità dei contenuti in 4k o dolby vision (sconnesse le cuffie e riavviato la TV ed è tornato apposto)
- ho spento il modem e quando l'ho riacceso ho dovuto togliere la corrente alla tv altrimenti non si connetteva ad Internet
Grazie mille per le vs. opinioni, un saluto
Questo aggiornamento "risolve" o dovrebbe risolvere il problema all'avvio quindi per i tuoi due, se imputabili al solo Sistema e non ad una combinazione tra dispositivi ed Applicazioni (o loro versioni) puoi tentare, anche dopo l'aggiornamento, un ripristino delle impostazioni di fabbrica.
dadaumpa87
Ciao Scusa non avevo allegato l'immagine. Essendo bug risolti con altri aggiornamenti, probabile che sia qualcosa presente anche sul modello xf90. o sbaglio?
Sì l'ultimo aggiornamento risolve solo il problem all'avvio ma comprende anche ovviamente gli aggiornamenti precedenti rilasciati a soluzione di altro...
Non ti resta che tentare ed eventualmente ripristinare se non risolvi, il ripristino consente la ricostruzione del Sistema e può mette a posto alcune cose che da sole, con il solo update, non si sistemano...
Flamerone
E' risaputo che netflix con le cuffie bluetooth scala tutto in FHD enon hai più il 4K. E' un problema di netflix visto che con amazon prime video non c'è invece nessun downscaling.
Giusto, mi ero perso la scelta / bug di Netflix...
