Suitable keyboard for xperia z??
SOLVED
profile.country.no_NO.title
sm32man
:slight_smile:Hi again
Does anyone know,if or when a good keyboard for the Xperia z will be available please?
many thanks Steve
1 ACCEPTED SOLUTION
profile.country.FR.title
ClarkLong
Well you can use any wired or wireless bluetooth keyboard with it
3 REPLIES 3
ClarkLong
lajkycz
New
But this is not ideál solution. Do you know some information about case with keyboard for tablet Z same as tablet S?
warsklar
Well, I think a wired keyboard would need an USB OTG adapter, which doesn't seem nice.  I picked up a cheap Bluetooth keyboard at Currys which works fine, it was £19.99.  Going to get a bluetooth mouse to see if it works.
