How do I disable the charging LED?
@Scopie wrote:How do I disable the charging LED?
I think it's impossible
How i know Sony Xperia smartphones don't have this feature, but maybe i just don't know about it
@NeoBeum wrote:
I wouldn't say impossible... You could drill in to it... If you really hated it that much.... I have a Dremel for such things. Good for taking apart hard drive chassis when the pentalobe screws head gets sheared
Good idea with drill
But i advise him just to cover led light, if you someday change your mind after drill you couldn't back led light
But for idea you got from me BIG applause
