WF-1000X Bluetooth Equalizer
dembala
New
Hi,
I am wondering if there is an Android app out there that can be used as equalizer for the Sony WF-1000X wireless earbuds. (First Gen)
The Sony Connect app has equalizer but only fixed settings can be triggered, I cannot create my own.
3rd party Bluetooth equalizer apps that I’ve tried so far have no effect on this Sony model, they don’t work even if the Sony app had been removed before installing these apps.
I would like to change the EQ to my taste for this earbuds and I cannot.
Can you help me?
thanks,
cheers
Balazs
4 REPLIES 4
Pascale_F
Hi dembala,
Welcome to the community.
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Dembala,
I think only the Headphones connect app will be working with the headphones.
Cheers,
The_Black_Rose
Sonyvores
Contributor
Which device are you using as a source?
You should be able to do it in the sound setting of the device except if its latest walkman.
profile.country.PK.title
Irshad.aziz
New
