Hi,
The description for this voice recorder states that:
"Now you can record those faint audio sources without capturing excessive background noise, thanks to the high-sensitivity, low-noise S-Microphone. Even the sound of birds twittering in the distance can be captured naturally and clearly."
What settings are the right ones for capturing sounds of birds twittering in the distance naturally and clearly?
Should I use music or voice, should I use noise reduction, etc.?
Thanks,
Morten [Denmark]
@mortenbo In that case I think voice will be better to capture the full spectrum of frequencies and Birds are primarily voice-based sounds: https://helpguide.sony.net/icd/u57/v1/en2/contents/TP0002426605.html?search=voice
Thanks for this. Happy new year!
