i think model# is NWZ-B133 & it freezes
profile.country.en_GB.title
QuestionMark
Visiteur
my mp3 freezes when ever i plug it into the USB slot OR when i turn the power on
when i turn the power on it says "walkman" for like 20 seconds which normally happens but then the screen goes black with a white rectangle in the middle of the screen (music doesnt play) and it needs to be reset
when i put it in the USB slot the screen will either be the same as i said before or stay black when i remove it it needs to be reset aswell
when it is plugged into the USB the computer recognises it as a "walkman" and i cant see any of the files on it
ANY help will be much appreciated thanks!
Message was edited by: QuestionMark
0 RÉPONSES 0
