Hi
I bought VPCEB3C5E in 2010, and I am looking for a replacement battery charger. Please can you let me know the cost for the replacement battery charger, and where can I buy this product?
REgards
Murali Gooty
Hi Murali Gooty and welcome.
This is the adapter you need but it looks like it is out of stock at Sony online store: -
http://www.sony.co.uk/product/ac-adapters/vgp-ac19v32#/Overview
However, it is much cheaper on Amazon: -
http://www.amazon.co.uk/ORIGINAL-VGP-AC19V32-CHARGER-ADAPTER-19-5V/dp/B004GHAD1Y
Hello, ,many thanks for your reply. I am sorry, I should have said the battery instea d of charger. I am actually looking for a Sony Vaio battery of the model specified in the subject line.
I am sorry once again.
Please can I have the cost for the battery?
Regards
Murali
Please can someone help me with Sony Vaio replacement battery.
Hi gmuralik,
You should be able to purchase a replacement battery from Vaio support to find the contact number click Support at the top of this page followed by Contact Us..
Then click on Vaio & computing..
Enter your vaio models serial number, which you should find on the bottom of your Vaio..
Then click Validate..
Then you should see the number to dial for Phone support..
