Hi
I bought a Vaio NS30Z and now refretting it due to the poor qulaity keyboard. Keys are wearing away, some keys don't work everytie and some double or treble hit......
I won't be buying another Sony product due to the very poor customer support on this issue..
Regards
Bryan
Hi Bryan.
I sympathise with your problem but as your Vaio is over 2 years old and a year out of warranty, I doubt you will get any further.
As you have operational problems as well as cosmetic ones it may be worth £40 to replace the keyboard completely (black & white available): -
http://www.laptop-part.co.uk/sony-vaio-vgn-nr-series-laptop-keyboard.html
However, you will quickly lose sympathy with your fellow users here if you continue to spam other threads which are over 5 years old.
Hi Bryan.
Thanks for the response but these things do take a number of years to come to light and this was the only post on the subject I could find to reply too..... Thanks...
