Nativecatori
New
Sonly VAIO Laptop
Hello, can anyone please help me solve the problem. I have replace the cmos battery.  When I turn it on I have operating  system is not found. I couldn’t reset bios and also the assist button do not work.also I did F12 I am getting Operating system not found.  Any suggestion what I need to do?A813137B-99E1-4E4E-B460-35BB562A1A5F.jpeg
3 REPLIES 3
Blencogo
Hi Nativecatori and welcome.
Your BIOS screen is showing ‘Hard Disc Drive = None’ so that is why the system cannot find the Operating System.
It is likely that the hard drive has failed but check that you have not unplugged the SATA cable when you replaced the CMOS battery.
The System Date is also showing 2010!!
Nativecatori
New
Thank you for replying I appreciate your time and effort. I need help where can I find the SATA cable. Can you share information where exactly the SATA cable locate?
Blencogo
It is the cable or ribbon that connects the hard disc drive to the main board.
As I said, it sounds like the hard drive has failed but it is always worth looking for a hardware problem, like a loose cable, just in case.
