I hope someone can help me as I've wasted so much time on this already...
I have a Vaio SZ1XP (NVIDIA Go 7400) and I'm trying to connect it to a Samsung 244T monitor.
The monitor simply does not recognize any signal coming in from the Vaio.
The monitor works perfectly well with analogue and/or digital signals from any other source, and the Vaio can drive other monitors (eg the small acer one normally attached to the desktop).
But the combination of the Vaio connected to the 244T simply doesn't work.
Can anyone point me in the right direction with this? I've updated to the latest drivers available from Sony (see dump below) and I'm not sure what else I can do...
Thanks in advance,
Brett
Driver config:
Components
nvCpl.cpl 1.0.8.13 NVIDIA nvCpl Control Panel Applet
nvExpBar.dll 1.0.8.13 NVIDIA nvCpl Explorer Bar
nvCplUI.exe 1.0.8.13 NVIDIA nvCpl Container
nvViTvS.dll6.14.10.8491 NVIDIA Compatible Windows 2000 Display driver, Version 84.91
nvMoblS.dll 6.14.10.8491 NVIDIA Compatible Windows 2000 Display driver, Version 84.91
NVMCTRAY.DLL 6.14.10.8491 NVIDIA Media Center Library
NVOGLNT.DLL 6.14.10.8491 NVIDIA Compatible OpenGL ICD
nvDispS.dll 6.14.10.8491 NVIDIA nvCpl Display Server
NVCPL.DLL 6.14.10.8491 NVIDIA Compatible Windows 2000 Display driver, Version 84.91
NV4_MINI.SYS 6.14.10.8491 NVIDIA Compatible Windows 2000 Miniport Driver, Version 84.91
NV4_DISP.DLL 6.14.10.8491 NVIDIA Compatible Windows 2000 Display driver, Version 84.91
nvGameS.dll 6.14.10.8491 NVIDIA nvCpl Game Configuration Server
i cant find "vaio event service" in the list of services
but i think my hotkeys are controlled by another program:
Hcontrol.exe, HKServ.exe, HKWnd.exe, i can see this programs running in the task manager,
i'm gonna try to shut these down and see if my monitor will work then
edit: this didnt seem to solve the problem 😞
then do what I did - shut all but the very, very necessary services down and see if the monitor then works.
then, turn each service back on until it stops working...
are you sure that the monitor works with other laptops, and that your laptop can drive other monitors?
The simplest way to get it working might be to reinstall windows afresh (try vista!) 🙂
B
it worked
but now i cant get my monitor to work on it's native resolution (1440*800)
is this because my graphic card is too old? (its a mobility radeon 9200)
okay thanks, i'm able to set the resolution to 1440*900 with the omega drivers... but this resolution doesnt seem to fit the screen...
but what's really weird is, when i set the resolution to a 4:3 one, it does fit the screen... so i think my screen is acting like a 4:3 while its actually wide screen... any ideas?
What do you mean with "it seems to does not fit the screen" ?
is it distorted, not centered or ís it looking like as if it's to big. So that you can scroll the picture with mouse movements?
May you have to use that auto-calibrate button of your TFT. Check your monitor setting too. (via the OSD menu)
Well, it will be to big for your VAIO screen, but it's the native resolution of your Samsung)
Im having the same problem with my Apple Cinema Display 23" on my ar11s docking station via dvi-d
Hy Keloo,
i have this problem: i have a samsung le27t51b lcd tv wich has a pc connection and i tried to connect it to my laptop but the image stays ther for like 5 second and i get 'no cable signal' message on the screen.
I killed the vaio event service but doesn't work anyway, do you have any ideeas?
please help
how do i do that
