I hope someone can help me as I've wasted so much time on this already...
I have a Vaio SZ1XP (NVIDIA Go 7400) and I'm trying to connect it to a Samsung 244T monitor.
The monitor simply does not recognize any signal coming in from the Vaio.
The monitor works perfectly well with analogue and/or digital signals from any other source, and the Vaio can drive other monitors (eg the small acer one normally attached to the desktop).
But the combination of the Vaio connected to the 244T simply doesn't work.
Can anyone point me in the right direction with this? I've updated to the latest drivers available from Sony (see dump below) and I'm not sure what else I can do...
Thanks in advance,
Brett
Driver config:
Components
nvCpl.cpl 1.0.8.13 NVIDIA nvCpl Control Panel Applet
nvExpBar.dll 1.0.8.13 NVIDIA nvCpl Explorer Bar
nvCplUI.exe 1.0.8.13 NVIDIA nvCpl Container
nvViTvS.dll6.14.10.8491 NVIDIA Compatible Windows 2000 Display driver, Version 84.91
nvMoblS.dll 6.14.10.8491 NVIDIA Compatible Windows 2000 Display driver, Version 84.91
NVMCTRAY.DLL 6.14.10.8491 NVIDIA Media Center Library
NVOGLNT.DLL 6.14.10.8491 NVIDIA Compatible OpenGL ICD
nvDispS.dll 6.14.10.8491 NVIDIA nvCpl Display Server
NVCPL.DLL 6.14.10.8491 NVIDIA Compatible Windows 2000 Display driver, Version 84.91
NV4_MINI.SYS 6.14.10.8491 NVIDIA Compatible Windows 2000 Miniport Driver, Version 84.91
NV4_DISP.DLL 6.14.10.8491 NVIDIA Compatible Windows 2000 Display driver, Version 84.91
nvGameS.dll 6.14.10.8491 NVIDIA nvCpl Game Configuration Server
if I could see the traffic between the monitor and the laptop, then I'd have a chance to understand why it is that Sony's Event Service is killing the connection...
As I say, the monitor works with everything else I plug into it...
And I can definitely say it's the event service since when I disable it, the monitor works with the vaio like a charm...
Only problem is then none of the Vaio's "function" (blue) keys work...
I'd say that's a small price to pay, they're pretty lame those keys anyway.
My new Vaio FE28b with GeForce 7400 doesn't even recognize my SyncMaster 940mw! How do I turn off Event Service to see if that's the problem?
right click on my computer (either in file manager or on desktop) -> Manage -> [expand] Services and Applications (on the left hand side tree) -> Services
now on the right hand side you can see a list of all services.
scroll down to VAIO Event Service
double click on it
Choose "Disabled" from the "startup type" drop down.
then ok.
To re-enable it, just put it back onto startup type of automatic.
Cheers,
Brett
hello i cant seem to find "vaio event service" ? i'm using windows in dutch language? maybe it has another name?
i have a VGN A115M laptop and a samsung syncmaster 940MW monitor with the same problems...
Hi Swinmon,
All you can do is double-click on all the VAIO Services until you find one with the executable file "VESMgr.exe".
it isn't there...?
are you sure al vaio laptops have this?
almost certain...
I've now done a complete fresh windows (vista) install on my machine, so I don't have ANY VAIO services anymore :-))
small price to pay to know that my machine is now working to it's full capability...:-)
cant find it :s
need some help
is the problem that you can't find the services, or that you can't find the "VAIO event service" in the list of services.
Of course it's possible that they renamed the service for the dutch windows, but I think it's very unlikely.
What other VAIO services can you see?
