Hi All,
Please need your help to identify if VPCF23B9E SONY VAIO laptop has inbuilt bluetooth adapter?
when i access VAIO Control center , unable to access Bluetooth, with VAIO SMART NETWORK. The Advanced option does not open. and does not show any inbuilt Bluetooth adapter
Thanks
Jack
Hi Jack,
Yes, it has Bluetooth.
Please refer to the IM how to activate:
https://www.sony.com/electronics/support/res/manuals/Z014/Z014246111.PDF
Cheers
Peter
Hi Peter,
Thank you for the reply!
I had gone through the manual , the BLUE TOOTH device icon isn't listed. I did also search for Bluetooth and not found. I am running Windows 7 home premium. ( The wireless Button is Enabled )
To allow other BLUETOOTH devices to communicate with your computer, follow these steps:
1 Click Start and Devices and Printers.
2 Right-click the BLUETOOTH device icon and click Bluetooth settings.
3 Click the Options tab and select the Allow Bluetooth devices to find this computer check box.
Also, the VAIO smart network Advanced does not show anything
Please let me know another checks/settings can be done?
Cheers!
Jack
Hey, normally you would need to download the driver, however, Sony has withdrew them for W7, https://www.sony.co.uk/electronics/support/laptop-pc-vpc-series/vpcf23b9e/articles/00189437
Are you able to update through the device itself?
