Partagez votre expérience!
What cable is best to connect to tv to use as monitor. Tv input is hdmi but what output port on pc should be used?
Résolu ! Accéder à la solution.
Hi aflemi,
welcome to Questions & Answers..:smileyhappy:
According to the specifications your VGN-N38Z does not have a HDMI output..
Does your TV have a VGA port if so you could try using that port to connect up your Vaio..
Or
You could try using a VGA to HDMI Convertor or something similar..
Hi aflemi,
Or
Txvm, tv has vga port so a straight vga cable should work ??
You're welcome, post back if you have any problems and we'll try to assist further..
