cancel
Showing results for
Search instead for
Did you mean:
problemas al actualizar la BIOS R1140T8 A LA R0300Y8 EN MY VAIO VPCEB3C5E
SOLVED
profile.country.ES.title
Jordi947
INTENTO ACTUALIZAR LA BIOS Y ME DICE QUE NO ES COMPATIBLE CON MI VPCEB3C5E CUANDO LLEVO CASI 3 AÑOS USANDOLO , EN EL SOPORTE DE WINDOWS ME HAN DICHO QUE MI LAPTOP ESTA BIEN Y QUE ES SONY EL RESPONSABLE DE DAR SOPORTE A WINDOWS PARA QUE FUNCIONE .
11 REPLIES 11
Jordi947
really thanks for your help. So I understand that I have no way to update my BIOS and if windows 7 which is the original OS of the laptop stops working, I will no longer be able to use my laptop ????
Joe_Dohn
Specialist
The OS will never stop working. The end of life announcement by Microsoft was regarding future security updates.
Most applications will continue to work, but you'll most probably need to upgrade the hardware at some point to keep up since technology improves quickly anyways.
