Hey,
I bought a sony 32w706 a few months ago. I don't know when exactly this started but now every time I turn on the tv I get this msg:
Some applications are unavailable due to boot error.
Please refer to the i-Manual for more information.
I have tried looking this up in the i-manual but don't find anything that helps.
There are indeed a few things that don't work. For example if I put in a usb key I can't access through the icon on hte right corner.
How do I fix this? How do I clear the boot error?
Thanks
Hi there
There are a few things you can try before contacting Support (of which they will get you to do anyway)
If things still do not work after that, there is probably not much this forum can help you with. Best to contact Sony Support : HERE
Let us know how you get on anyway - im curious to know
Cheers
Hi there
This sounds to me like the USB drive is inserted into the TV as you turn it on AND is a USB drive failure. Try removing the USB drive then turn the TV on and see if this error message still comes up.
Cheers.
Hello,
There is no usb in the tv.
I get this error all the time and I have nothing connected to it except the BT box.
Hi there
Cheers
Hey,
It did work.
I updated the software but I believe it was the reset that did the trick.
Thanks for the help.
i disconnected bt box then reconnected. it seems to have cured fault.
I got exactly the same error. I did that procedure and it worked. But some days later the message apears again. Then i try to do the same and didn`t work. Can you help?
Thanks in advance and sorry for the bad english
