Xperia Mini Pro Won't Update!!!! Phone is dead!!!! Need Help!!!
SOLVED
Not applicable
Hello
I tried updating my phone with pc companion and it failed. It only got 50%!!!
Now my phone will not turn on. It won't flash with the service tool or pc companion or the flash tool from XDA!!!
Is my phone faulty? If not what can I do???
Thanks.
21 REPLIES 21
Not applicable
Is there any other drivers I can download to try? I will try another usb cable in the morning.
Thanks.
that should do it PCC and SEUS just try a new Micro USB
Not applicable
I just thought I'd plug the phone in to the usb and leave it on charge but after about a minute, the green light goes out then comes back on about 5 seconds later, as if the phone is rebooting.
Does this mean there is a problem?
Thanks.
remove the SD card, the phone might be trying to turn on to mount the SD card, do you have another micro USB cable?
Not applicable
I've removed the SD card and connected it to the usb again, this time the light came on for about 30 seconds, went off for about 5 seconds, came back on again for about 30 seconds and now the light stays off. I can't try a different usb cable until I get in work tomorrow and use someones blackberry cable. The phone was brand new though, only got it today from the o2 website.
in that case you should return it, it might be a faulty device
Not applicable
Well if the a different usb cable doesn't work tomorrow, I will have to return it.
I would just return it, just in case there's something else wrong with it, but yeah a new USB cable might do the trick
Not applicable
A different USB cable didn't work, now o2 are saying they have no more in stock and are not getting anymore in stock. Pathetic! Now I'm going to have to go out and spend £250 for a phone that I should have got for £130!! Won't be getting another mini pro that's for sure.
Not applicable
I just tried "buying" one on their website - just to see if it said "out of stock" and it accepted the transaction - no notice about it being unavailable.   You could try contacting them again and asking to speak to a supervisor - tell them that the phone is still being sold so you don't see how they can claim it is out of stock.
Having said that - flashing (or trying to) with a third-party application may have invalidated your warranty.  If you're lucky, that won't be picked up on because - from your description - it sounds like that flash never really affected the phone anyway - probably because the phone was not in USB Debugging mode.
Had you done anything at all to the phone - rooting, flashing a third-party ROM etc - before the failed attempt using the SE update tool?   If not and if O2 are genuinely out of stock, you have no comeback other than a refund of the price of the phone - unless both you and O2 are willing to consider a repair.   If you'd done anything to invalidate the warranty, you could - in theory at least - be in trouble as far as O2 goes but that wouldn't stop you seeing if a local repair shop can take a look - it may be something they can do quickly and cheaply - might be worth considering before you shell-out for another phone.
Before that though - just confirm exactly what happens when you try using PC Companion.   Does PCC show your phone as connected via USB?   If so, does it say the phone is up to date or does it say an update is avialable?   If it says it is up to date, have you tried running the updater again and - if so - did you get the screen asking if you want to repair the installation?   If it says there is an update available, it is acknowledging that the phone did not update - which should put your mind at rest regarding the warranty.   If there is any other message - perhaps saying something to the effect of your phone not being suitable for updates, that would usually indicate that the phone had been rooted or has a non-standard ROM installed.
One other thing - and it's one of the those "obvious" things to try - pull the battery and wait a few minutes before powering on.   If there's any signs of life, bear in mind that the first boot-up after an update/repair can take several minutes so give it time.   Also, some phones have been known to work better with rooting and flashing tools if the SD and SIM cards are removed first - might be worth a try if you want to continue trying with unofficial flashing tools.
