Unable to synchronise with Outlook
SOLVED
Not applicable
My phone is a C905, software is up to date.I am running  PC companion 2.0 ( upgraded automatically). It will not synchronise with Outlook 2007. It stalls when I get the message that Outlook is not my default emal client and I should alter settings to correct this. I will not change my email client. Does anyone know how I can complete the synchronisation.
1 ACCEPTED SOLUTION
Johan
Master
MS Outlook needs to be set as default E-mail client in order for PC Companion to sync with it. So I suggest that you set it as default E-mail client.
Note that the only thing that changes if you set MS Outlook to default client is what program that starts when you press a E-mail link on your PC.
2 REPLIES 2
Johan
Master
Not applicable
Thanks very much, worked well. Will just change the default client when I need to synchronise
