my mobile (w205) can't read other sim card
SOLVED
Not applicable
Hi, I need a code to unlock my mobile (w205) for other sim card. Where can I find it???
1 ACCEPTED SOLUTION
Dr_Chris
Champion
The safest way is to contact your mobile provider/network and ask them for the network unlocking code.There's usually a charge for this, depending on the terms and conditions, but you would get charged for the code anyway if you chose to obtain it from elsewhere, and in that case, you can't be sure of getting the correct code, or any code at all.
5 REPLIES 5
Dr_Chris
Champion
Not applicable
Thank you Dr chris for your answer. You're right, I should ask to my mobile network, I will try.
But the point is that, I've already ask to someone else (on internet), and I've paid for this service, and they told me that the code doesn't exist yet. That sonyericsson doesn't create it yet, so they supposed to me to ask directly to sony. That's why I'm here now.
I would like, someone from sony, see my messages, contact me and give me this code. I really need it the more fastly posible.
Dr_Chris
Champion
I don't know who you talked to on the internet, but since the phone is locked, this means that an unlocking code exists because it's usually based on the IMEI number of the phone.It simply sounds that the code hasn't yet been released to people that sell them on the internet, but it's the mobile network that the phone is locked into that usually holds the code, or at least they will be able to get it for you.
Not applicable
Ok, you're certainly right. It's seems logical like that. So I will go and see my network. I hope it will be ok. I tell you then.
Thank you Dr Chris.
Dr_Chris
Champion
No problem.Hope this gets resolved.
