is sony ericson cedar have landscape mode available while playing video files?
SOLVED
Not applicable
hi,
     i want to know the deatails regarding the video playing & compatible files that has been asociated with cedar and also i want to know the charging time required for the phone.......plz help me ...plz any one.......
1 ACCEPTED SOLUTION
Dr_Chris
Champion
Both internet and Youtube access & performance are dependent on the speed of the mobile network that you're using.At the moment, I cannot play Youtube videos on my W995 via 3G (T-mobile) because it appears that my network doesn't support the new flash version on which it's running, although it's not a problem over WiFi. In some cases, accessing Youtube may also depend on the phone's customisation and/or the location that you're in.
4 REPLIES 4
Dr_Chris
Champion
http://developer.sonyericsson.com/wportal/devworld/phones/phone-overview/cedar?cc=gb&lc=en See under Audio & video for compatible file formats.
Yes, video should play in landscape and battery charging time from flat to full is about 2 and a half hours.
Not applicable
one more thing i wud like to know is whether the internet acessing via cedar is good or not?also whatz the performance of youtube application in cedar?
Dr_Chris
Champion
marantz777
In several countries, as example in italy, (and using some carriers like tre or fastweb), youtube on cedar simply does not work at all, only black screens.
