hi all,
I've just updated my Xperia Mini to ICS, and it is a wonderfull update.. worth to wait it for so long.. đ
but, I encountered one problem on app setting. when I select on an app (in running tab and all tab), when I press back the menu always return to downloaded tab (the default one when first open apps setting), so it very frustated me when I kill many apps (I need to start from top list and scroll to bottom to find my next app), not like in GB when kill or press back will return to the latest list we opened.
and also when open app from app drawer, when press back it always return to home, not return to app list like in GB.
is anyone also encounter this issue, or just me because of bad update process??
thanks for the answer..
but i've discovered the source of the problem, it's the "don't keep activities".. so when i press back it always back to home screen.
in setting->developer option->don't keep activities..
i've deactivated that, and the problem gone..
Everything is working as it is supposed to
Instead on back button use home key
First of all go to settings > apps > running > Press home key >
Now press and hold home key and you will get the list of most recent apps > tap on settings and you will be redirected to running apps list
