Please can anyone help?
A while ago I saw a tip for a way of adding multiple numbers to the contacts shortcut on the homescreen - I did it on a couple! Now I want to do this for another contact & I can't remember how to do it and despite searching the site I can't find anything here. To try to explain, when you long press and select a shortcut for a contact when you then press the green call button on the left to call them, you get a list of numbers to select from. I just can't figure out what you do to achieve this.
Many thanks.
Thank you all for your help.
I was so driven crazy by this that I added a 'fake' contact which worked correctly. I have no idea what I did originally when I entered my contacts, but have just spent a load of time amending them all by deleting & re-inserting all the phone numbers, it all now works perfectly. It seems like the phone numbers were being treated like text fields by the phone, but it was dialling correctly......
All is now well.
