Hi,
I have an Xperia Ray. I set my alarm ( preinstalled ) clock the day before. Turn off the mobile phone as i did with my K750i.
But it is not ringing at the preset time ( yes I have checked the time twice)...
Any hints?
br,
//mike
it will not ring if your phone is off.. it never will...
i think its the android and not sony's fault..
best thing you can do is to put your phone into airplane mode
this way you wont get disturbed by any calls or messages , but still alarm will work
indeed it's android not SE, iOS doesn't do it neither
