How to insert sim
Asbid
How to insert sim
Plz tell me how to put in and put out sim in Xperia m2
Is that like sd card or sim jacket come out
11 REPLIES 11
Hampus
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you take a look at the user guide for Xperia M2. Check page 7 at the following link and you'll find info about how to insert the SIM-card:
http://www-support-downloads.sonymobile.com/d2303/userguide_EN_D2303-D2305-D2306_1_Android4.3.pdf
profile.country.RO.title
_alexdon_
Check out this pic:
Inserting the micro SIM card on Sony Xperia™
M2
alexdon
Asbid
Thank u guys
_alexdon_
Anytime.
alexdon
cristinamartine
Hello community
I bought my phone in Chile use it with Virgin Mobile company. The following week trip to Argentina with another sim and the system was upgraded with Sony Companion but upon returning to Chile sim no longer recognizes the Xperia M2 therefore I do not have the apn  enabled
csik
my five cents on the sim slot
i am a 50+  and i did not see that there is a dummy sim inside if you buy phone - i was trying several times to insert the micro sim before i checked it out that there is already a little black already inside
would be a great help to figure that out in the quick start manual
shahinurnpi
Thanks
Fastyan
Some times it's a small protection. Sim inside from everyone that don't know you have to remove it to get the Sim in
Tilly2017
My Sony m2 comes up saying no sim no service even with the sim card in it
