Romo
USB-OTG
Has Xperia L USB-OTG? Smarthphones like Xperia U, Xperia S(2012) have it.
1 ACCEPTED SOLUTION
Alexander1
Champion
Xperia L does not support USB-OTG. However some models support the USB-host standard (like Xperia S), which allows you to connect USB devices to your phone via a USB Host cable/adapter.
I just tested this with the Xperia L and it didn't seem to work.
What are your thoughts about this forum? Let us know by doing this short survey.
8 REPLIES 8
Alexander1
Champion
cableguy4
Will support be added soon?
its basic part of android since ice to have usb otg
Alexander1
Champion
I haven't heard about any plans to change this anytime soon.
cableguy4
ok, but i dont really understand why it was dropped, it was in most Xperia's since the Arc.
Will see if a firmware update brings it back, if not I will put on a custom Rom to get the feature.
cableguy4
I can see in the folder /sys/bus/usb/devices/ that when I plug in a USB flash drive/USB mouse it is recognised as a usb1 folder appears and using the app USB Device Info that its showing up as Qualcomm On-Chip EHCI Host Controller with 2.0 root hub
cableguy4
Verified USB OTG is working following the steps below.  Slightly_smiling_Face
http://forum.xda-developers.com/showthread.php?t=2427150
panni
REQUEST TO START SUPPORT OF USB OTG IN XPERIA L(C2104)
pruthvikraj
HI Support,
Am using Xperia L C210,  If i connect OTG..connector for USB it's not working?
PLease release some update to connect to OTG connector. Am using Sony from 2005.
Am fan of Sony . I love the music am using all the prodects sony only.
Am able to do screen sharing everything . PLease give a saloution for OTG connectvity ...Dont igonor for the same.
