Sony Xperia L3
Sony Xperia L3
Hi
Quick review of my Xperia L3. I don't consider myself as one of those 'must have the latest tech' type of person but I do like to have a mobile I can rely on but is sim free and not expensive. Having had my previous Huawei for two years, I felt I needed a change and started to look around for a suitable replacement. Having done a bit of reviewing, I decided upon the Xperia L3. Big mistake. This phone is nothing short of abysmal. Right from the get go it has failed to come even close to my previous phones in terms of quality or reliability. I have tried numerous times to get it to work properly with various upgrades and reboots but all to no avail. While it feels like a good solid piece of kit, I would have preferred if Sony had invested a bit more in the software for this phone. It is glitch, temperamental and has numerous issues with basic functions. It repeatedly fails to connect to Bluetooth devices or just simply disconnects itself which is very annoying. The fingerprint scanner works intermittently and it sometimes simply won't open up apps. In short, the worst phone I have ever had and so after just 10 months of ownership, it is heading for the bin to be replaced with another Huawei. I suggest Sony bin it as well.
2 REPLIES 2
Anonymous
Not applicable
Hi there,
I'll pass this on and a community member should get back to you.
Best wishes,
M
Za3bola
Specialist
@GaiusMarius64 Sometimes the issue is more software then hardware, have you tried updating the phone software and having all the apps up to date?
