- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello,
My phone can't on and when i try to on it just show SONY icon in long duration plus my phone getting hot. Any solution ?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
With the information supplied, I can only advise that you try to perform a software repair on the device, this should help resolve the issue, this is also done with the handset turned off.
Please see the instructions below.
1. Download the PC Companion software from PC Companion and install it on your PC.
2. Install and open PC Companion then select Support Zone.
3. Phone Software Update.
4. Start.
5. Repair Phone
6. Continue
7. Accept data removal
8. Next
9. Wait for prepare
10. Select Phone
11. Follow the connection steps
If this does not help, please come back and let us know.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you, i will try but can i asak one more question.
When i already download the PC Companion, in the same time do i need to connect my phone? For your information my computer cannot detect my phone device. So, the PC Companion is still worked without connect my phone?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You will eventually connect the phone to the PC, however it will be in a certain way and the device will stay turned off during the process. You should have no issues even if PC Companion cannot see the device when connected.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello,
I had try your solution and it work but, my camera show ' Camera not available'. What is mean and you have any solution?
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Please help me for this problem, because my job need use camera from my phone.
I opened any solution from others that k=heve same problem with me.
