L1 blocking
Mari_2110
L1 blocking
El botón lateral de desbloqueo y bloqueo no funciona bien, aveces no responde, existe alguna otra forma de desbloquear cuando se encuentra inactivo?
The side unlock and lock button does not work well, sometimes it does not respond, is there any other way to unlock when idle?
gt
1 REPLY 1
profile.country.PH.title
MarlonUk1
hello @Mari_2110
try to long press on the power button to restart the device , try to see if you can unlock it after restart
