ashraf13
Flash Problem
hello. i bought a new xperia L but why i can't turn on the flash when i touch into the flash icon in camera apps??
1 ACCEPTED SOLUTION
thomasacquins
Hello brother Flash will not work when HDR mode is ON. That's not a problem .Turn off  HDR mode then you can access the flash setting.OK
16 REPLIES 16
Bhishma_C_K
Can u post a pic?
ashraf13
yes. this is the picture. i'm use xperia L,android 4.1.2 build number 150.0.A.1.31
you look at the flash icon. it does't shine like the other icon. when i touch to on the flash,it doesn't respond. what the problem??
jaggerkieth
Try to reset your Camera Settings. Goto Settings > Apps > Camera > Clear Cache and Clear Data. If it doesn't work try to factory rest your phone.
thomasacquins
ashraf13
thanks.. i'm newly in using the android system. thanks..
mrseven
Hey friend my camera flash is not working neither in camera nor in other apps which uses flash
ennealee
Same here. I've had the phone since June and my flash has stopped working, both in camera and apps.
Jdev
Any updates on this? Im having the same problem Xperia C. It started when I installed a flashlight app Super-Bright LED Flashlight
Paulol1
you have to turn off the HDR.
