32,332  Views
The following FAQ explains the different options available Twin Picture functionalities:
To display two pictures, follow the steps below:
STEP 1: Select the HDMI input that the device is connected to.
  1. Press the HOME button on the remote.
  2. Select Inputs.
  3. Select HDMI 1-4.
STEP 2: Select Twin Picture from the ACTION MENU.
  1. Press the ACTION MENU button on the remote.
  2. Select Twin Picture.
STEP 3: To end Twin Picture mode, select Single Picture from the ACTION MENU.
NOTES:
  • The TV cannot enter Twin Picture mode unless an HDMI input is selected
  • The only signals that can be displayed in Twin Picture mode are Digital 2K and analogue signals
  • The Twin Picture display function is available via a software update. Update to the latest software, and then check whether it is displayed in the menu.
