- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I cannot get any sound from the HT-XT3 when connecting to my Bravia KD-49X8005C TV using HDMI ARC. The only way I can get it to work is with the optical cable connection. What could be wrong?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Assuming that you have connected it to the HDMI-ARC port on the TV, it could be the HDMI cable itself - so, if the below instructions dont work, try a new hdmi cable.
It could also be a HDMI handshake issue, because you plugged it in when the tv was on. Try this:
- Turn TV completely off from the wall.
- Unplug optical cable, and plug in the HDMI cable to the correct ports.
- Turn TV on and test.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Many thanks, turning off at the wall and starting again worked.
Cheers
Steve
