- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
HT CT370 Soundbar Compatibility with Sky Q UHD
I have just had Sky Q installed and I cannot obtain a UHD signal through my Soundbar. I have had to wire direct from Sky Q Box to TV set.
Instructions suggest that the soundbar is compaitible, can anyone help?
Simon.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Depending upon what resolution and colour bit depth you have your Sky Q Silver box set to, the HT-CT370 only supports 8bit for 2160p@50hz/60hz. See chart below:
Also, you havnt mentioned what TV you have, but if its not a Sony, you will need to change the pass-through HDMI settings from "Auto" to "ON".
Even after all that, I am unsure if this soundbar is compatible with HDCP 2.2 - which is required for the Sky Q Silver box
However to be frank, I would leave the Sky Q Silver box connected directly to the TV - this is the recommended configuration at this current time.
Cheers
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Quinnicus sorry for the late response, I missed your post somehow but many thanks for getting back to me. I have a Sony Bravia KD-65X850B which has 4K resolution. Also I'm afraid I'm not a Techie so some of the terms you're using are lost on me.
After using a sound bar the sound quality is far superior to the TV speaker system so I'm going to leave it set on the soundbar for now until I can get some more guidance.
All the best,
Simon.
