- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
STR-DN1080 and Music center wifi problems
Hi,
just got my STR-DN1080 almost up and running perfectly. But I have one problem connected to the music center app. So this is the problem:
1. At first setup I got wifi connection to the app.
2. But after standby mode (receiver off) it can only connect via bluetooth.
3. If I disconnect the ethernet cable and put it back in - it will work (but it pretty annoying to do that each time)
I have tried with both wired and wireless setup. And the same happens (except that with wireless there is no way to disconnect without pulling the electricity plug of the receiver).
I have also tried every tips and trick - just like the person here: https://community.sony.ee/t5/hi-fi-systems/str-dn1080-home-network-issue/m-p/2546918
So is this a hardware issue? Or software that can be fixed? Or some hidden setting that is hard to locate?
Brds
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Tertis,
Can you please confirm, that your receiver is running the latest firmware?
Cheers
Peter
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
it says no update available, and current version is M41.R.0445 which seems to be the newest also.
Brds
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Solution for me: I conducted a full power reset of both modem and router. Then it started working with wifi connection after standby.
The only thing I hope now is on the next update - is possibility to turn on the receiver from music center when in standby mode also for European models.
Consider this ticket solved.
Brds
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Having the exact same issue, it connected via wifi once, now it will not do so again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Having the same issue as well. Hope Sony will fix this quickly .
