Hi all,
I recently received a Sony Turntable as a gift (PS-LX310BT) and have tried to hook it up with my bluetooth speaker. The turntable and speak pair together just fine, but there's no sound at all coming from the speaker when I try to play a record.
I paired the turntable with a JBL Go speaker and my Bose QuietComfort headphones but the same issue happens on both.
Any ideas on how to get this working?
Thanks!
Hello tray agaien blutooth to conect the spiker
I have the same issue can connect to lots of Bluetooth devices but no ply back from any of them from turntable.
The Manual (page 12) mentions setting the Output selector to Line when using Bluetooth, are you using these settings?
Hi
Have you solved this as I have the same issue?
Do you have no sound at all or is it a very faint?
I’ve had my player for 5 weeks, it connected to Bluetooth fine and played aloud.
3 days ago I switched my player on and it connected to my Amazon Echo as auto paired and I was not getting any play back.
I then paired it yesterday with another of my Bluetooth speakers and it paired but play back was faint and the volume wouldn’t adjust despite being set to the right output (line).
I yesterday ordered a new Bluetooth speaker a Sony one SRS-XB23 and I now cannot pair the two at all? I’ve now retired my original amazon echo and again it pairs fine but no play back?
so odd as pairs fine with 2 devices one offers no play back, the other offers faint play back and the new Sony speaker won’t even pair? Any ideas?
Thanks.
There isn't a direct factory reset method for the PS-LX310BT. try keeping it unplugged from the mains for a while before connecting again as it could just be a glitch.
On one speaker I have no sound and on the other it’s very faint.
Ok thank will try that. It’s switched off at mains but guess you mean switched off and fully unplugged?
