Gi
I have a Sony headset wh-1000xm3 that I connect to my iPhone via Bluetooth.
Albeit is it connected easily to the phone, sometimes it makes a sound and it disconnects for few second and it reconnects automatically.
additonally when I push the bottom nc ambient, it says that it is unable to connect to the network.
can somebody help me ?
I did not have these problems at the beginning
many thanks
Hi,
Please make sure that the latest firmware is installed on your headphones. Please use the headphones connect software to update the software.
Cheers
Peter
Have you tried a factory reset of the headphones? Maybe also try them with other phones to see if the same happens
Hey, have you tried this: https://helpguide.sony.net/mdr/wh1000xm3/v1/en/contents/TP0001703078.html ? Did you try other phones?
