- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
XAV-AX3005DB - USB device not supported
Just installed a XAV-AX3005DB in my Vivaro van. All good except that I get a repeating message (plus four beeps!) saying 'USB device is unsupported' but, to the best of my knowledge, there are no USB devices connected to the unit. I have tried using the 'factory reset' option but the problem remains.
There is a similar post from 2020 which seems to suggest a solution but the link to the solution doesn't go anywhere.
Suggestions please.
NeilJay
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
Make sure the firmware is up to date: https://www.sony.co.uk/electronics/support/mobile-cd-players-digital-media-players-xav-series/xav-ax...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Contacted Sony. They advised a) check firmware is 1.25 b) do a factory reset c) send it to Sony for assessment. Firmware is v1.25 and have done Factory Reset. Do I really have to remove the unit and send it to Sony?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
Yes you need to send it for inspection, couldn't find any work around here.
