Hi. I'm looking to upgrade my current Tom tom navigation in my Sony XNV-L77BT. Would anybody know if the new Plug-in Car Navigation Module XA-NV400 unit is compatible and how easy the upgrade would be???
Thank you... Tony
Hi there,
Welcome to the community.
Hopefully one of the forum members will be able to help.
Best wishes,
M
Hi tonyberezny,
Welcome to our community!
I tied to check if there's any information available about the compatibility of both devices but unfortunately couldn't find any. I passed your question on to Sony support and will get back to you with their answer once it's availablele.
Cheers,
Batee5
Hi tonyberezny,
Apologies for the delay.
I just received an update from Sony support that the XA-NV400 Navigation Module is not compatible with the Sony XNV-L77BT.
Regards,
Batee5
