Could anyone tell me how to get any any extra lens,s etc. for this camera or filters?
Hi @Icbutcher
Your camera is A-Mount so will take Sony A-mount lenses (and a couple of other manufacturers too)
Have a look Here for the range of Sony lenses compatible with your 68K
You may be able to find some cheaper elsewhere on line,
but always make sure they're a reputed retailer before ordering.
Cheers
Hi @Icbutcher
Cheers
Thank you for your help
You're welcome
