profile.country.fr_FR.title
midarq
Visiteur
lamp
Hi
My reader is only 5 months old and the side lamp does not work...
Is it normal ? How do I change it?
Do I have to pay for it?
Thank you
Michele
1 SOLUTION APPROUVÉE
Solutions approuvées
profile.country.en_GB.title
carpetmojo
Membre
Hello midarq - by side lamp, I presume you mean the light on a Sony cover ? A flexible arm with light that lights up when swivelled upwards to illuminate the reader page ?
It can simply be the battery needs renewing - rechargeable ones are OK, although battery life is good on these lamps. The battery is changed through a flip lid in the left side of the cover - shouldn't break your nails, it opens fairly easily !
The other reason may be the bulb needs changing - haven't done this myself, but should be standard maintainance level..... I'll have a look tomorrow.
Try the battery first anyway, it's the most likely.
Hope this helps.
Voir la solution dans l'envoi d'origine
1 RÉPONSE 1
carpetmojo
Membre
Hope this helps.
