- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
August 2018
August 2018
Setting SD card as default storage location for E5
I've had my E5 for over a year and I still haven't figured out how to change my default storage to my SD card instead of internal storage. Please help if you know how so I don't have to change each app's storage location individually like I've been doing this whole time.
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2018
September 2018
Bonjour j'ai exactement le même soucis, je n'arrive pas à mettre en place un téléchargement sur la carte sd. Avez-vous trouvé la solution ? Merci
Hello I have exactly the same problem, I can not put a download on the map sd. Have you found the solution? Thank you
gt
