- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I cant't repair with pc companion the message "su telefono esta actualizado .... no existe software para este dispositivo . And can't install facebook my phone is not compatiple
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I've solved the problem whith de following instructions form your technical SERVICE .
Dentro del programa Pc Companion, inicie "Support Zone" sin conectar el cable USB, cuando seleccione "Actualizar software", le indicará que no detecta su terminal y que si tiene problemas con el mismo "Repare" el teléfono. Seleccione esta opción y siga las instrucciones del programa. Conecte al cable USB unicamente cuando el programa lo indique.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Is this the problem you have?
Beware that it is Xperia E thread.I will move it accordingly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
So you have tried a software repair,correct?
