mein Handy lässt sich nicht neustarten obwohl es an ist ,lässt sich aber auch nicht ausschalten, was kann ich machen??????
my phone can not be restarted although it is on, but can not turn off, what can I do ??????
GT
Hi @Struppi70,
As this is a international community your previous post has been translated in to English, please keep all future posts in English so that other user may understand you better.
I'm sorry to hear this.
I recommend that you try to force your device to shut down. To do so;
I'd also recommend that you try to temporarily remove any SIM and SD card from your device to see if they may be causing this behavior.
If you are still unable to restart your device I recommend that you try to perform a software repair using Xperia Companion.
Let me know how it goes.
