Mostrar resultados para
Pesquisar em vez de
Queria dizer:
In Abu Dhabi. UAE {{+971563725701)]] Abortion Pills in Dubai/Sharjah.-09
profile.country.ES.title
naty01
Novo
Abortion Pills in Dubai – Abu Dhabi Sharjah +971563725701
there are many pregnant women who want to have an abortion with medication. Due to the demand for confidentiality or fear of abortion, some patients want to abort using drugs. You should consult your doctor about how to use drugs. Sometimes the use of these drugs can be risky. Therefore, use the abortion medicine with the help of a doctor, not yourself. Abortion Drugs are Cytotec and Misoprostol. Sale and use of these drugs is prohibited.
What do I need to do before I take the abortion pill?
Before you take the abortion pill, you'll meet with your nurse, doctor, or health center staff to talk about whether abortion is the right decision for you, and what your abortion options are. You'll get an exam and lab tests, and you may get an ultrasound to figure out how far into your pregnancy you are.
Your nurse or doctor will let you know if there's anything else you need to do to prepare for your abortion. They'll give you written instructions on how to take your pills. You will have access to a caring professional through the process — you'll get a number you can call 24/7 if you have any questions or concerns.
You'll have a lot of bleeding and cramping after you take the second medicine, so plan ahead to make the process more comfortable. You can be at home, or wherever is comfortable for you to rest. You may also want to have someone you trust with you (or nearby) that you can call for support if you need anything
Stock up on maxi pads, food, books, movies, or whatever you like to help pass the time, and a heating pad for cramps. Make sure you have some pain medicine — but don't take aspirin because it can make you bleed more.
What happens during a medication abortion?
The abortion pill process has several steps and includes two different medicines.
First, you take a pill called mifepristone. This medicine stops the pregnancy from growing. Some people feel nauseous or start bleeding after taking mifepristone, but it's not common. Your doctor or nurse may also give you antibiotics to take to prevent infection.
The second medicine is called misoprostol. You'll either take the misoprostol right away, or up to 48 hours after you take the first pill — your doctor or nurse will let you know how and when to take it. This medicine causes cramping and bleeding to empty your uterus.
For most people, cramping and bleeding usually starts 1-4 hours after taking the misoprostol. It's normal to see large blood clots (up to the size of a lemon) or clumps of tissue when this is happening. It's kind of like having a really heavy, cramps period, and the process is very similar to an early miscarriage. (If you don't have any bleeding within 24 hours after taking the second medicine, misoprostol, call your nurse or doctor.)
The cramping and bleeding can last for several hours. Most people finish passing the pregnancy tissue in 4-5 hours, but it may take longer. The cramping and bleeding slows down after the pregnancy tissue comes out. You may have cramping on and off for 1 or 2 more days.
You can take pain medicine like ibuprofen about 30 minutes before you take the second medicine, misoprostol, to help with cramps. You can also take anti-nausea medicine if your doctor or nurse gives it to you. Don't take aspirin, because it can make you bleed more.
It's normal to have some bleeding and spotting for several weeks after your abortion. You can use pads, tampons, or a menstrual cup — whatever's the most comfortable for you. But your nurse or doctor may recommend you use pads for the first few days after the abortion so you can track how much you're bleeding.
The last step is to follow up with your nurse or doctor. You may go back into the health centre for an ultrasound or blood test. Or you'll get a pregnancy test to take at home, followed by a phone call with your nurse or doctor. These tests will make sure the abortion worked and that you're healthy.
In the unlikely case that the abortion doesn't work and you're still pregnant, your doctor or nurse will discuss your options with you. You may need another dose of medication or to have an in-clinic procedure to complete the abortion. Abortion pills (Dubai) +971563725701 UAE. How to use Misoprostol – 200 mcg and Mifepristone for a safely induced miscarriage/pregnancy termination (abortion) in United Arab Emirates. Abortion Pills in Dubai| Abu Dhabi +971563725701|Sharjah| Fujairah| Al Ain-mifepristone & Misoprostol Available in Dubai| Abu Dhabi-Cytotec in Dubai |JVC| Ajman| RAK City Abortion Pills in Dubai| Abu Dhabi +971563725701Sharjah| Fujairah| Al Ain Abortion Pills in Dubai| Abu Dhabi +971563725701|Sharjah| Fujairah| Al Ain-mifepristone & Misoprostol Available in Dubai| Abu Dhabi-Cytotec in Dubai |JVC| Ajman| RAK City Abortion Pills in Dubai| Abu Dhabi +971563725701Sharjah| Fujairah| Al Ain Abortion Pills in Dubai| Abu Dhabi +971563725701|Sharjah| Fujairah| Al Ain-mifepristone & Misoprostol Available in Dubai| Abu Dhabi-Cytotec in Dubai |JVC| Ajman| RAK City Abortion Pills in Dubai| Abu Dhabi +971563725701Sharjah| Fujairah| Al Ain Abortion Pills in Dubai| Abu Dhabi +971563725701|Sharjah| Fujairah| Al Ain-mifepristone & Misoprostol Available in Dubai| Abu Dhabi-Cytotec in Dubai |JVC| Ajman| RAK City Abortion Pills in Dubai| Abu Dhabi +971563725701Sharjah| Fujairah| Al Ain Abortion Pills in Dubai| Abu Dhabi +971563725701|Sharjah| Fujairah| Al Ain-mifepristone & Misoprostol Available in Dubai| Abu Dhabi-Cytotec in Dubai |JVC| Ajman| RAK City Abortion Pills in Dubai| Abu Dhabi +971563725701Sharjah| Fujairah| Al Ain
"+971563725701>Таблетки для ***** в Дубае, мифепристон и мизопростол в Дубае, Абу-Даби - цитотек, Abortion pills DUBAI -Таблетки для ***** Дубай +971563725701 Мизопростол |Cytotec |ABUDHABI|SHARJAH| купить CYTOTEC Мифепристон и мизопростол СЕКРЕТНАЯ ДОСТАВКА +971551311906 КУПИТЬ ТАБЛЕТКИ ДЛЯ ***** В АБУ-ДАБИ, АЛЬ-АЙНЕ, ДУБАЙ, ШАРДЖА, ОАЭ. Свяжитесь с Пэм по ее прямому номеру + для медицинской процедуры *****, которая прервет вашу беременность. Это базовая медицинская потребность для миллионов женщин, девочек и других людей, которые могут забеременеть в Дубае / ОАЭ, Катаре / Дохе, Кувейте и во всех других частях мира. По оценкам, 1 из 4 беременностей заканчивается абортом каждый год, поэтому не стесняйтесь, если вы не готовы стать матерью, потому что это ваша жизнь, и вы сами решаете, что вам делать. Но хотя необходимость в абортах в Дубае/ОАЭ широко распространена, доступ к безопасным и легальным услугам по прерыванию беременности далеко не гарантирован тем, кому могут потребоваться услуги по прерыванию беременности; именно поэтому доктор Лин здесь, чтобы спасти вас, потому что она понимает, каково это, поэтому свяжитесь с ней для получения лучшей поддержки в этой ситуации по ее личному прямому номеру.
من
​النساء الحوامل اللواتي يرغبن
في الإجهاض بالأدوية. 1 الإجهاض باستخدام الأدوية. يجب عليك استشارة طبيبك حول كيفية استخدام الأدوية. بالمخاطر. لذلك ، استعملي دواء الإجهاض بمساعدة طبيب وليس بنفسك. أدوية الإجهاض هي سيتوتك وميسوبروستول. يحظر بيع واستخدام هذه الأدوية
0 RESPOSTAS 0
