LIVE LIFE LOUD with the new SRS-XV900 Wireless Speaker
_J.G.M_
873  Views
Sony has announced the launch of the new SRS-XV900, the most powerful and loudest Bluetooth party speaker in the wireless speaker X-series range. The speaker forms part of the “LIVE LIFE LOUD” vision to deliver exciting sound entertainment experiences to music lovers around the world. Life should be lived at full volume and that means being able to enjoy clear, rich sound from Sony’s new SRS-XV900 speaker to make the most of every single moment.
Fill your home with high sound pressure with Omnidirectional Party Sound
Enjoy Powerful omnidirectional sound with the SRS-XV900. This wireless speaker is designed to fill the space with sound. The speaker comes with the X-Balanced Speaker Unit and its non-circular diaphragm gives more sound pressure and reduces sound distortion by maximising the area of the speaker as well as the Jet Bass Booster port to deliver deep, punchy, powerful bass. The midrange drivers provide excellent vocal clarity and the 6 tweeters front, side and back spread high-frequency sound all around.
Long lasting battery life
You can now take your sound anywhere around your home with 25-hour[1] battery life on the SRS-XV900 that will keep the music going day and night. If you find your speaker running out of battery, there’s no need to worry. With the speaker’s quick charging, you can get 3 hours of playing time from just 10 minutes of charging. With the Battery Care Mode feature, you never have to worry about overcharging your speaker, making it more dependable for longer.
Convenient handle and wheels to easily move the speaker around your home
The product comes with a convenient handle and wheels. Whenever you want to move the speaker, take hold of the carry handle and tilt it back. Sturdy castors let you roll all the way to the party!
TV Sound Booster connectivity to enhance your TV sound experience
The SRS-XV900 speaker features Sony’s unique function, TV Sound Booster that lets you enjoy enhanced sound when watching TV. Deep bass and realistic high-frequency sound from the SRS-XV900 fills the room and boosts your TV’s sound to provide a rich audio-visual experience, whether you are watching live performance videos or movies. Simply connect the optical cable (included) and select TV Sound Booster mode to any TV brand or model.
Fun and Entertaining features
Love karaoke? Then you and the SRS-XV900 speaker will make a perfect double act. Plug in your microphone, pick a song, and give it everything you’ve got. And don’t stop at singing. With two inputs (mic & guitar), you can even plug in a guitar and use the speaker as an amp. By using the Fiestable mobile app and its new Double Tracking karaoke function, your singing vocals will be enriched to make the singing voice more comfortable.
And if that wasn´t enough, you will always have complete control of the speaker with the intuitive top touch panel that allows you to change function, settings and lighting with just a touch.
MEGA BASS and LIVE SOUND
The MEGA BASS feature allows you to dial up the bass on your speaker, providing you with deep and punchy bass. With the new SRS-XV900 speaker, you can enjoy your music like it is live whilst the LIVE SOUND mode lets you recreate that unique atmosphere and re-live your favourite music experiences, over and over again. LIVE LIFE LOUD and create memorable moments with the SRS-XV900.
Easy connectivity and Bluetooth pairing
Party Connect via Bluetooth® allows you to connect up to 100 compatible Sony Bluetooth speakers[1] to enjoy synchronised sound and lighting for an extra large party and to make sure everyone’s dancing to the same beat. In addition, the speaker allows you to plug in and play music with USB connectivity. And if your smartphone is running low on battery, you can even plug it into the speaker and have it charged directly.
The SRS-XV900 also allows you to instantly connect the speaker to your smartphone using Bluetooth fast pair for Android.
Sony | Music Center and Fiestable
The new SRS-XV900 is compatible with both Sony | Music Center and Fiestable apps. With Sony | Music Center you can select playlists, cue the next song, change lighting patterns, and sound modes all from the dance floor. Fiestable allows you to access fun features to help create the ultimate party atmosphere, such as making a party playlist, karaoke functions including Voice Changer and Echo, plus DJ control to add sound effects.
Sustainability matters
Sony´s products are designed to deliver industry-leading sound quality and also to consider the environment. Sony’s originally developed recycled plastic is used in the front and rear panels and internal parts of the SRS-XV900 speaker, reflecting how Sony strives to reduce the environmental impact of its products.
Price and availability
The SRS-XV900 speaker will be available for purchase in Europe from October 2022 for an estimated retail price of €1199 / £999.
[1] When MEGA BASS on, the volume level is set to 16, and lighting is off. Actual performance may vary from the listed time due to the volume, songs played, surrounding temperature, and usage conditions.
[2] Only compatible between SRS-XB43, SRS-XB33, SRS-XB23, SRS-XP700, SRS-XP500, SRS-XG500, SRS-XG300, SRS-XE300, SRS-XE200, LSPX-S3. Products compatible with the Wireless Party Chain function are not applicable for connection.
