Why is it so difficult (impossible) to cointact Sony Support
room_101
My RX100 camerta has suddenly developed the infamous "C:32:60, Turn power off then on" error. Of course, the suggested solution(s) don't work so I'd like to arrange for it to be repaired. Whys is this so difficult ? After eventually navigating the endless loops of Q&A I finally got to a page that would allow some sort of contact. Chat is never accessible and each time after filling out the Email or Call us forms,  it fails with a "Oh no! Your details were not stored! Please try again in an hour or so." message.
And so it goes on and on.
7 REPLIES 7
danardeng
Contributor
room_101
I think you are missing the point. and besides most of these service centers linit themselves to Sonys' DSLR and mirrorless cameras not compact Cybershots.
danardeng
Contributor
I know that sony's website is tricky, and sometimes it doesn't work as it should.
Probably online support send you to your nearest service center after some unuseful questions. It's the reason of my suggestion.
room_101
Indeed it is tricky danardeng and I appreciate your intent.
FWIW, the website contact page does appear to work despite  issuing messages to try again and have since received a repair form. So I will look at that and decide based on the cost of repair.
Cheers.
HannahEd01
Hey room_101,
You can email directly to: [email protected].
The chat is available and works right away through this link: https://services.sony.co.uk/supportmvc/en/Contact/Email?cat=mobile&tab=Chat
Or maybe just call, they give you the option to skip the whole create your case thingy.
room_101
Thank you for providing a direct email address.
As for the chat and call options, I did say that I tried those and failed .. on a number of occasions.
Patience and saints comes to mind.
HannahEd01
 Here are the direct numbers:
UK: 0207 365 2810
IE: 140 733 41
